Rear and front USB Ports suddenly stopped working
Zmeya
Hey,
I have a fairly old second PC I only use for work and since today not a sinlge USB Port works. What I find curios is, that not only the USB Ports in the rear don't work, but the USB Ports in the front IO of my case are dead too. When I boot up, all devices light up like usual (my mouse for example) and as soon as windows loads, everything went dark and nothing works. Obviously I tested all devices on my gaming pc, everythink works fine.
Can this be a problem with windows or my mainboard? Anyone got an idea?
How are you able to control the system?? If possible check device manager to see if the USB controller driver got messed up by Windows Update perhaps.
Might need to break out an old PS/2 keyboard to get the job done, or bite the bullet and spend $15 on a 120GB SSD to test it with a 2nd install.
My rig:
CPU: Ryzen 5 3600 3.6Ghz, OC'ed to 4.2Ghz all core @ 1.25v + Corsair H60 120mm AIO
MB: Gigabyte B450 I Aorus Pro WiFi
RAM: Kingston Fury Beast RGB 32GB (2x16GB) 3600mhz CL16 (1-to-1 Infinity Fabric enabled)
GPU: Gigabyte RTX 2080 Super
*bought for $200 CAD off a friend who needed an RTX 3080, price was my reward.
CASE: InWinn A1 Plus in White with included 600w gold sfx PSU and included custom length cables
DISPLAY: 3x 20" AOC 1080p 60hz 4ms ,  32" RCA 1080p/60hz TV mounted above, all on a single arm.
Storage: C : 1TB WD Blue NVMe      D : 2TB Barracuda      E: 240GB Kingston V300 (scratch drive)
NAS: 240GB Kingston A400 + 6x 10+ year old 700GB Barracuda drives in my old FX8350+8GB DDR3 system
Logitech G15 1st Gen + Logitech G602 Wireless
Steam Controller +  Elite Series 2 controller + Logitech G29 Racing Wheel + Wingman Extreme Digital 3D Flight Stick
Sennheiser HD 4.40 Headphones + Pixel Buds 2 + Logitech Z213 2.1 Speakers
My Girlfriends Weeb-Ass Rig:
Razer Blade Pro 17 2020
10th Gen i7 10875H 8c/16t @5.1ghz
17.3" 1080p 300Hz 100% sRGB, factory calibrated, 6mm bezel
RTX 2070 Max-Q 8GB
512GB generic NVMe
16GB (2x8GB) DDR4 3200Mhz
Wireless-AX201 (802.11a/b/g/n/ac/ax), Bluetooth® 5.1, 2.5Gbit Ethernet
70.5 Whr Battery
Razer Huntsman Quartz, Razer Balistic Quartz, Razer Kraken Quartz Kitty Heaphones
*deep breath*
Razer Raptor 27" monitor, IT'S BEAUTIFUL.
