You basically need switches that support the Spanning Tree Protocol. So you'll probably need 3 managed switches.
Yes, with three managed switches you can create a mesh - 1 -> 2, 3, 2 -> 1, 3 and 3 -> 1, 2
Using STP enabled on all three will put redundant, loop, links into a blocking state. If a link goes down, STP can detect it and switch a port from blocking to forwarding. Only thing, it isn't instant... Most managed switches will support this kind of thing.
Taking it a step further, you could also make each connection with multiple ports in trunk mode. This would give even more redundancy...
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
This is what you should listen to.
You need STP on the switches for it to work otherwise it will be a endless loop. Look up STP it's neat how it works.
“Everything in excess! To enjoy the flavor of life, take big bites. Moderation is for monks.”
