FTTH signal attenuation
By
Alireza
in Networking
in Networking
Solved by PyCCo_TyPuCTo,
Yes, it's perfectly fine.
It means that the difference between Transmit light level and Receive light level on the other side of the fiber is 15.5dB.
For example if at the ISP office they Tx light at +5dBm, then your Rx level at that box is -10dBm. That's all it is. It means nothing in terms of speeds or latency you can get out of that connection.
Featured Topics
1
1
2
Emilerk ·
Posted in Troubleshooting0 -
4
peacenattress ·
Posted in Graphics Cards3 -
Oxphos ·
Posted in Troubleshooting4
