1x4 pin + 1x8 pin for 12400F + TUF B660M
Solved by RONOTHAN##,
7 minutes ago, Gamer Guy said:Even though 12400F doesn't need more than 1x 8-pin, from which 12th gen CPU, when paired up with this board, will I require that extra 4-Pin connector? Is that something I can buy one extra from Corsair and plug it in when I upgrade in future to like 12700/13700 tier CPUs running at stock?
The 8 pin header, at minimum, can supply 384w. The closest anything on LGA 1700 currently gets to that is the 12900k which draws about 230w under full load, well under the 384w the 8 pin can supply. I'd highly doubt a future 13900k will draw more than ~250w under full load because that would be nearly impossible to cool, so that extra 4 pin header is just on the board for aesthetic reasons, it serves no functional purpose.
