CPU Liquid Cooling or Air Cooling
Solved by DoctorNick,
Just now, RMTM said:Thanks for the suggestion.
Cant go wrong. They're great value (280 is the best value most of the time)
Only thing I would get is a tube of Noctua paste, NT-H1/H2, so you don't have to deal with thermal compound in a bag. Also if you're new to installing custom colers. Make sure that the bracket is tighten all the way down to the motherboard, before installing the cooler. Make sure to use a blob of thermal compound about the size of a chickpea in the middle of the cpu (heatspreader). Let the cooler squeeze of the paste and mount in one motion. Try mounting the cooler before applying thermal compound the first time.
