Build help
Go to solution Solved by MonkeyNutsUK,
Thank you for all your help I will have a look now, sorry about the list this is the the pc part link I had https://uk.pcpartpicker.com/list/GZrr78
Budget (including currency): £1200
Country: Uk
Games, programs or workloads that it will be used for: Davinci resolve 4k, Photoshop,
I have build a base but it is currently around £1800
But I was trying to get it down to £1200 but I can go over a bit if needed I'm open to part changes as long as there good for the programs I'm using. The storage Idea was to have a boot the. A m.2 for programs and a HDD for photo and video storage.
Part list.
Intel core i7 – 12 700k
Nzxt kraken x63
Gigabyte z390 gaming x ddr4 ATX LGA 1700
Corsair vengeance RGB RS 32GB 2 x 16 GB ddr4  3600
Seagate barracuda 5TB
Samsung 970 Evo Plus 250gb m.2
Crucial p5 2TB m.2
EVGA GeForce RTX 2060 12 GB XC black gaming video card
Nzxt h510 elite ATX mid Tower case
Corsair RM 2019 850w
Thank you for any help
https://linustechtips.com/topic/1413041-build-help/
You need to use uk.pcpartpicker.com for your list. Post the permalink or cut & paste the BB formatted text.
The OP build contains incompatible parts.
I7-12700K cpu require Z690, H670, B660, or H610 motherboards. Z690 is really the. Most appropriate for that cpu.
There are other issues.
https://linustechtips.com/topic/1413041-build-help/#findComment-15270501
These will not work with each other. The Z390 board is LGA 1151v2, and the 12700k is LGA 1700, you cant put the CPU in that motherboard.
Nzxt kraken x63
go for a dual tower cooler instead. It'll perform well enough for a 12700k, cost less, and be more reliable.
Make sure it's the CL16 version.
6TB drives are cheaper.
omit this. It's really expensive for what you get, it's not really enough storage, and the P5 would do just just as well.
Go for another case, that is a hot box that costs way too much money. The P400a digital is a good option, same with the Corsair 4000D.
You don't need a 850w unit, a 750 would do just as well
https://uk.pcpartpicker.com/list/RXW3Fg
https://linustechtips.com/topic/1413041-build-help/#findComment-15270701
https://uk.pcpartpicker.com/list/GksLDq
Base is now 1150£
Cooler is an nhd15 competitor for cheap so expect decent performance out of it, just dont expect to get any decent cpu oc cause cpu oc is dead (unless you manage to run <60c load with beefy cooling and decent volt like 1.4-1.5v)
Board is cheap but should be capable of decent oc
Rams are ballistix, single rank and micron dies allow upto 4500+ cl18 if you really care about bandwidth but a more sensible oc would be a lazy oc to 4000 cl16 (1.4-1.5v)
Overkilled on the hdd, cut down on ssd
Cheaper better airflow case
Cheaper psu
https://linustechtips.com/topic/1413041-build-help/#findComment-15270877
