Overclocking potential with i7 9700KF, one 4 pin CPU mobo header.
Solved by Somerandomtechyboi,
5 minutes ago, BigRecoiilz said:My friend has a very "budget motherboard" and it only has one 4 pin CPU header.
Its prob not a z board so rip oc, maybe you can use throttlestop but its quite pointless when the boards vrm is gonna start burning on any sort of oc xD
6 minutes ago, BigRecoiilz said:One 4 pin CPU mobo slot can handle up to approx. 150 watts
Thats the official spec, since its a spec you can actually draw more than what its designed for but ofc not reccomended cause cables or connectors can literally start melting but minor overspec like 175w i dont really see a problem with
