Got hacked pls help!
The safest thing would be to use the Windows Media Creation Tool with a USB flash drive. Make sure to get the Tool directly from Microsoft and most definitely use a different machine to get it with. That way the flash drive won't be infected when downloaded.
Using the Tool, delete all the partitions on the infected boot drive (c:) and then repartition and format. Then do the install. While you are doing this install, do not connect to the internet in any way. Unplug any internet cables and disconnect any antennae. This will do a standalone install and then only after that is complete, then you can connect the internet cable/antennae again. First thing after connecting to internet and Microsoft updates are downloaded/installed be sure the Microsoft Defender/Antivirus in installed and running.
After this you should be good to go.
Good Luck.
