A intel cpu without a k at the end is not overclockable in a hardware level
I have an ASUS G14 2021 with Manjaro KDE and I am a professional Linux NoOB and also pretty bad at General Computing.
ALSO I DON'T EDIT MY POSTS* NOWADAYS SO NO NEED TO REFRESH BEFORE REPLYING *unless I edit my post
https://linustechtips.com/topic/1409402-overclock-guid-please/#findComment-15244823
1 hour ago, YUOSEF said:
i have GIGABYTE P61A-D3 motherboard with i5-2400
how can i overclock it
any option softwher or bios
i want to try overclock it to 3.7
You cant overclock non-k chips, and you need a Z series motherboard to overclock a k series chip. Without both of those things, you can't overclock an intel CPU.
https://linustechtips.com/topic/1409402-overclock-guid-please/#findComment-15244824
