Hi,
I'm looking to make a cheap home mesh wifi network under 200 euro. I was looking at tp link omada setups but they get just over budget when we add a poe switch. What else would be good budget setups?
It's not really needing to do much just provide good wifi between 4 floors. 1 on floor 0 and 1 on floor 2 as those are the most used ones. Currently there is only one good fritzbox router on floor 0 and the wifi in the attic is a bit poor garden reception isn't great either but it will be fixed by a router in the attic as we have tested.
So what would be a good lower budget solution?
https://linustechtips.com/topic/1409362-home-mesh-wifi-setup/
