I'm hoping to find info that will allow me to stub UEFI setup of curtain devices at a specific time (specific time before windows is even involved). EFI commands I've tried on a Xeon system, do nothing. Trying to game on a Tesla M40 which supposedly requires pure UEFI mode (CSM disabled), and 4GB decoding of course. But I got it installed (with no device manager errors like "code 10") by fluke once while my output GPU was an HD6770. The HD6770 does not output to display with CSM enabled (when I try the bios auto enables CSM, hate that; just stop doing anything with it and hand everything off to windows). Can't get it to happen again. I tried getting it to boot without CSM the lazy way of getting the BIOS/UEFI to ignore the 6770... unplugging the PSU from it, then booting. I just wanted to check device manager logs after next reboot to see if it was set up while I couldn't see windows. I can't explain why it worked, because I had a black screen until plugging power back in. I can only speculate that it was a fluke perfect timing of plugging things in to bypass a check the UEFI does.
https://linustechtips.com/topic/1408966-efi-shell-commands-ryzen-system/
You cant do anything there. HD6770 does not have UEFI GOP in its vbios, none of cards of that generation does. Meaning you cant have HD6770 in that system while having CSM disabled and have any display output. ALSO, DO NOT unplug and plug power to graphics card while your system is powered on.
Edited by Levent
vbios not drivers
... I learned nothing there; advice not accepted.
Yesterday I booted the system without the HD6770 installed but it's power plugged in, then hot plugged it 🙂
