Why does does the transfer speed decrease?
Go to solution Solved by Spotty,
26 minutes ago, Elijah Kamski said:
Btw, moving from an SSD to a HDD.
You're always going to be limited by the slowest drive you are reading from or writing to, which in this case would be the HDD. 145MB/s seems about what you would get for a HDD write speed. The faster bit at the start would be when it is being cached.
3 minutes ago, Elijah Kamski said:
Also how can I solve it?
I really hate this as i transfer a large amount of files which are in themselves large.
What HDD model is it and how much data are you transferring at a time? Larger files or small ones (images)?
its probably when the dram chache on the ssd runs out
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
Ah okay, makes sense.
Got any recommendations on M.2 SSD's maybe?
Thanks,
Eli
2 hours ago, Elijah Kamski said:
Makes sense, thanks for the info!
Do you recommend any good M.2 SSD's that have big DRAM caches on a budget?
Not really, cache is standardly 1gb per tb of storage iirc, it doesn’t really get bigger without a bigger drive
Bios database
prior build:
