Please HELP fix this issue with win10
Go to solution Solved by LordWk,
On 1/31/2022 at 6:42 PM, Fiveros said:
Hi, i have a problem , when i restart or shut down my pc it always show this i don't know what is this and why it appears.
Anybody knows how to fix it
win10 pro
here is an image
If it happens always you can try:
Open Task Manager > Startup > Disable any program that you find suspicious or that you don't want to be open at startup.
Or
Open searchbar > type msconfig > services > click on the squarebox that says don't show microsoft services > remove the ones you consider non-essential.
Maybe this will fix it, if it does fix it, it will be shown AFTER the first restart.
try shutting down programs that aren't essential windows programs (through task manager) one at a time before shutdowns, whichever one you closed before shutting down without that issue is your problem. might be better ways, but that's what i would try.
nothing helped idk what to do
win10 pro
here is an image
Or
CPU: Ryzen 5 3600 @ 4.4GHz 1.2v / GPU: MSI Radeon RX 5700 Mech OC GP (5700XT Bios) @ 2GHz / MB: Asus ROG Strix B450-F / RAM: Kingston HyperX 16GB DDR4 3200MHz CL16 / CASE: MSI MAG Vampiric 010X
there is a program running that shouldn't be, go though the list of programs running in task manager more thoroughly, it may take time, but there isn't a quick solution. also, run a full system scan with windows defender, you definitely could have a virus or malware causing this issue.
i did with eset nod32 and defender and nothing , i will try with task manager to search somethign
Or
it helped but still don't know what was that thing, thx, i forgot about msconfig 😄
