Budget (including currency): 1500€
Country: Slovenia
Games, programs or workloads that it will be used for: csgo, rainbow 6...
Other details: Here is the current parts list: https://at.pcpartpicker.com/list/JqRPxs
All prices are manually set to what I could find at a local retailer / on Amazon that ships here. Please take a look at the list and let me know if there's anything wrong with it or if it can be improved.
https://linustechtips.com/topic/1407767-need-help-with-new-build/
Country: Slovenia
Other details: Here is the current parts list: https://pcpartpicker.com/list/szWRsL
500GB is DEFENITLY not enough, go for at least 1TB ssd
--PC SPECS--
CPU: I7-12700k
CPU Cooler: MSI MEG S360
GPU: GTX 1070 STRIX 8GB
MOBO: Asus Z690-A D4 WIFI
RAM: Corsair Vengeance RGB Pro 32GB DDR4
SSD: Samsung QVO 2TB
SSD: Samsung EVO 500GB
HDD: Seagate Barracuda 250 GB
Case: Lian-li O11 Mid Black
https://uk.pcpartpicker.com/list/xsfFW3
If you can find them in your area for a good price, go for a Corsair CXF 80+ Bronze PSU. They're fully modular and are highly reviewed/rated. There's also a white version that will go better with your case, if you want, too.. https://pcpartpicker.com/product/3Hwkcf/
You may have to remove that extra case fan from your list for now, but the 275R Airflow comes with an intake and exhaust fan already. You can just add more fans later. 🙂
Am I still to create the perfect system?! ~ Clu
Keep your expectations low, boy, and you will never be disappointed. ~ Kratos
Thanks, found a white CX550F 550W for 70€. For the case fan, I read that a good setup is to put the 3 included fans as front intake and another one for exhaust, that's why I have the additional one on the list.
I would recommend keeping the ones pre-installed where they are. So 2 at the front, and 1 at the back of the case. Your case comes with 3 pre-installed fans already. 2 at the front (as intake fans), and 1 at the back (as an exhaust fan). You don't really need another case fan, because you're also putting in a decent aftermarket cpu cooler, which will also help with airflow. You might want to later put one more case fan at the top-rear of the case, as an exhaust fan. However, that's only if you're not getting desired temperatures from your build. The 275R Airflow case is a case I have built in before too, and those included case fans are more than enough. Hope it helps! 🙂
Edited by GeorgeMKane
Thanks so much for all the help. This is the final list, also had to change the gpu because shipping complications. https://at.pcpartpicker.com/list/ZPrgXy
I didn't notice it before, but you may also want to get a full nvme ssd. that m.2 ssd you have in your list isn't nvme, so it will be as fast as a regular 2.5" SSD. If the nvme ssd is too much, just go for a decent 1tb 2.5" SSD. They may cost about the same as the ssd you have in your list.
