I need help building my first pc 馃槬
7 hours ago, City said:I have done all the cables for the psu its the cables for the fans leds power button all the small connectors stuff i have a b550 auros master mb. Like i said its my first time building one聽
Use the manuals. Seriously. The ones you need are for will be for the case, motherboard, power supply, and any additional cooling/airflow hardware you have.
聽
Here are the things you'll need to look for in the manuals:
- Power connectors for the motherboard and GPU
- Front I/O (This includes USB, front panel audio, and case buttons)
- Fans/CPU fan headers
- Fan/case RGB headers
- Storage (you'll need to connect most storage to the motherboard as well as the power supply)
聽
If you're having trouble with the RGB headers and power button headers, you definitely should look at the motherboard manual. Everything is labeled nicely there. Also, there are aRGB and RGB headers. A lot of modern motherboards have both, now, but make sure to plug your fans into the one with the right number of pins.
