Hello,
I just got my h100i, 750d case and some fans to day. I moved my system over to my new case and installed the h100i and fans and all that. All fine.
Then I got windows and all updates installed, I installed Corsair link version 2.4.5110. it says my pump on the corsair h100i is running at 2185 rpm. Is this correct? And it says my CPU temp is about 30-32 Celsius while my ASUS AI Suite says it is 19-21 Celsius. Which one should I trust?
post-66974-0-91560200-1397685258_thumb.j
post-66974-0-62012900-1397685127_thumb.p
https://linustechtips.com/topic/140677-h100i-problems/
as the other guy said the fans ramp upt to full on boot to check if it's working and to blow out dust etc, as for your temperatures, the asus suite seems to report abnormally low temps, the cpu temp will not go below ambient temperature, i think the temp you see in the corsair software is the liquid temp inside the loop, so your cpu could be a couple degrees hotter than what it shows, i would say asus suite is wrong here, unless you are running your computer inside the fridge, i would say the corsair temp seems somewhat accurate.
as for your pump, i don't think you can adjust the rpm of it, it just runs where it wants to run with the power fed to it as they don't want you screwing around with the pump speed and mess things up, the pump has a really high rpm and gives off quite abit off vibration/noise, so nothing to worry about, it's working like inteded, the pump speed should be correct and they don't allow you to change it through the software.
https://linustechtips.com/topic/140677-h100i-problems/#findComment-1878013
as the other guy said the fans ramp upt to full on boot to check if it's working and to blow out dust etc, as for your temperatures, the asus suite seems to report abnormally low temps, the cpu temp will not go below ambient temperature, i think the temp you see in the corsair software is the liquid temp inside the loop, so your cpu could be a couple degrees hotter than what it shows, i would say asus suite is wrong heree, unless you are running your cumputer inside the fridge, i would say the corsair temp seems somewhat accurate.
Yep, the pump will always hover at 2300rpm more or less
The joys of the hydro series
https://linustechtips.com/topic/140677-h100i-problems/#findComment-1878025
Guest
