Blurry After Going 4K
Go to solution Solved by Abdullatif,
That is correct, except the scaling is set to 175% since the text becomes very small for me to see. I fixed the blurriness by going to each application that is blurry and enabled the set override dpi scalling, select "application". Origin is the only app that the text still looks small, but I can deal with that.
Hello,
I have switched from 1080P monitor to 4K. I have noticed that many apps are blurry even though I have enabled some settings that prevent that, but the window becomes very small, so I'm stuck with either a small window or blurry normal size window. Any tips?
Currently, I'm running 1070 GTX which I'm thinking of upgrading later, not sure if the problem could be from the GPU.
https://linustechtips.com/topic/1406254-blurry-after-going-4k/
Can you confirm the system is set to 3840x2160 and 100% display scaling?
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
https://linustechtips.com/topic/1406254-blurry-after-going-4k/#findComment-15223688
https://linustechtips.com/topic/1406254-blurry-after-going-4k/#findComment-15223699
