So doing a new build but for first time ever I'm not using any HDD's. I'm going to have two 2.5" SSD's mounted on back of case. So my question is in regards to number of fans needed. I have a Kraken NZXT AIO for my CPU which will be mounted on top and one rear exhaust fan. So for the front I have 3 120mm thermaltake fans. I'm going to use the two for the top and middle but do I need that third one for bottoms since I won't have any HDD's to cool? Here is my case.
https://www.newegg.com/white-corsair-4000d-airflow-atx-mid-tower/p/N82E16811139157?Item=N82E16811139157&nm_mc=AFC-RAN-COM&cm_mmc=AFC-RAN-COM&utm_medium=affiliates&utm_source=afc-PCPartPicker&AFFID=2558510&AFFNAME=PCPartPicker&ACRID=1&ASID=https%3a%2f%2fpcpartpicker.com%2f&ranMID=44583&ranEAID=2558510&ranSiteID=8BacdVP0GFs-a0_dSfSQVUG4mjcxb1kHdA
https://linustechtips.com/topic/1404357-required-fans/
You don't need it and tell you what. Take the bottom front fan and place it just in line with the PSU shroud and I think that will be more effective at providing your graphics card with fresh air than with 3 fans in the front. So you'll have one fan providing air to the VRM area and the radiator and one for the graphics card. Sounds sensible?
https://linustechtips.com/topic/1404357-required-fans/#findComment-15210014
Great case!
When I built my PC last year using the 4000D, I ran some tests with 0,1,2,3 front fans. I’ve since altered my fan profiles & changed my CPU fan (& perhaps more but can’t recall), but here’s some stats you can use as reference…
Under Load…
3 x Front fans-GPU under load
‘Quiet’ Fan Profile for CPU/Case fans. GPU fans @ default restricted PWM threshold (66%)…
  • CPU (120mm x1); 1010RPM
  • Rear exhaust (120mm x1); 642RPM
  • Top exhaust (120mm x1); 635RPM
  • Front intake (120mm x3); 567RPM
  • GPU (80mm x2); ~1567RPM
Noise: 39dB Average
Temps: 98° (GPU Hot Spot), 86° (GPU), 42° (CPU)
2 x Front fans-GPU under load
  • CPU (120mm x1); 1009RPM
  • Rear exhaust (120mm x1); 635RPM
  • Top exhaust (120mm x1); 636RPM
  • Front intake (120mm x2); 564RPM
  • GPU (80mm x2); ~1500RPM
Noise: 39dB Average
Temps: 99°, 85°, 42°
1 x Front fan-GPU under load
  • CPU (120mm x1); 926RPM
  • Rear exhaust (120mm x1); 549RPM
  • Top exhaust (120mm x1); 544RPM
  • Front intake (120mm x1); 549RPM
  • GPU (80mm x2); ~1290RPM
Noise: 38dB Average
Temps: 95°, 83°, 39°
No Front fans-GPU under load
  • CPU (120mm x1); 983RPM
  • Rear exhaust (120mm x1); 628RPM
  • Top exhaust (120mm x1); 602RPM
  • GPU (80mm x2); ~1418RPM
Noise: 38dB Average
Temps: 97°, 85°, 44°
Idle…
3 x Front fans-GPU Idle
  • CPU (120mm x1); 966RPM
  • Rear exhaust (120mm x1); 609RPM
  • Top exhaust (120mm x1); 591RPM
  • Front intake (120mm x3); 569RPM
  • GPU (80mm x2); 0RPM
Noise: 37dB Average
50-48-37°
2 x Front fans-GPU Idle
  • CPU (120mm x1); 996RPM
  • Rear exhaust (120mm x1); 643RPM
  • Top exhaust (120mm x1); 616RPM
  • Front intake (120mm x2); 576RPM
Noise: 37dB Average
51-49-38°
1 x Front fan-GPU Idle
  • CPU (120mm x1); 956RPM
  • Rear exhaust (120mm x1); 574RPM
  • Top exhaust (120mm x1); 559RPM
  • Front intake (120mm x1); 551RPM
Noise: 35dB Average
53-50-38°
No Front fans-GPU Idle
  • CPU (120mm x1); 970RPM
  • Rear exhaust (120mm x1); 612RPM
  • Top exhaust (120mm x1); 580RPM
  • GPU (80mm x2); ~547RPM
Noise: 36dB Average
53-51-49°
https://linustechtips.com/topic/1404357-required-fans/#findComment-15210653
