USB on Power Off
Go to solution Solved by TPA50,
First, if you haven't already, make sure the BIOS is the latest version from this page:
https://rog.asus.com/us/motherboards/rog-strix/rog-strix-b550-f-gaming-model/helpdesk_bios
If that doesn't work follow the instructions in this video, since it's an Asus motherboard the BIOS screen should look very similar.
Hello Everyone,
I have recently upgraded my PC and got a new USB microphone and RGB Mouspad. My computer has a glass front and is in my bed room so I would like to disable all glowy things when the machine is powered down.
I have already turned USB Power on Soft Off (S2) and Motherboard RGB Lighting on Soft in my MBs BIOS Off off in the Motherboard settings but my USB devices keep being lit up at night and my motherboard RBG does not turn off either.
Do  any of you know a fix to this? Is there a setting I am not aware off that needs to be toggled?
Thank you to everyone who help save my sleep!
Hardware affected:
ASUS ROG Strix Gaming B550-F
Logitech Powerplay Mousepad
Streamplifiy USB Mic
https://linustechtips.com/topic/1403476-usb-on-power-off/
https://linustechtips.com/topic/1403476-usb-on-power-off/#findComment-15204133
