Hi
I bought a H105 AIO and installed it with two NF-F12 in pull, but the pump is a little noisy.
Since the pump runs of a 3-pin to a motherboard PWM heater, i was thinking if i put a Noctua LNA or Ultra LNA, would it slow down the pump and hopefully lower noise?
Tried to lower RPM through the bios but nothing happened.
Or do someone have a other maybe better solution? :)
GPU: MSI GTX 770 gaming || CPU: Intel 4670k @ 4.4Ghz || RAM: 4x4GB 1600mhz Corsair vengeance pro || MOBO: MSI Z87-GD65 Gaming || CPU cooler: Corsair H105 || PSU: Corsair RM650 || SSD: Samsung 840 EVO 120GB, Crucial M4 128GB || Case: Fractal Design Arc Midi R2 || Monitor: ASUS PA238Q
https://linustechtips.com/topic/140318-h105-pump-noise/
All AIO solutions have noisy pumps. That's just no way around it, if they were as silent as air cooling, they would be terrible performers. You don't buy AIO coolers for silence, you buy it for asthethics.
CPU: Intel Core i7 2600k | Mootherboard: ASUS P8z68v-Pro | GPU: EVGA GTX780Ti 3GB | RAM: Kingston HyperX Genesis 8GB (4GBx2) 1600mhz | PSU: Corsair AX760 | STORAGE: Samsung 840 Pro 512GB | COOLER: Noctua NH-C14 | CASE: Fractal Design Define R4 Pearl Black | Operating SystemWindows 7 Professional 64-bit |
https://linustechtips.com/topic/140318-h105-pump-noise/#findComment-1872526
damn, thats too bad :)
what if i chained 4 low-noise-adapters and 2 ultra-low-noise-adapters together between the pump and motherboard ;)
https://linustechtips.com/topic/140318-h105-pump-noise/#findComment-1872533
  • 3 months later...
Okay this might be a silly idea but i got my h105 pump hooked up to a pwm case fan header and the fans to the actual cpu headers. By what i can see and hear i can easily control the pump speed based on cpu temperatures but im not sure if its meant to be used like that? i had the pump on 30% base and quiet profile for a few days and its dead silent, temperatures didnt really suffer either.
CPU: Intel i7 3770k + Corsair H105 Motherboard: ASUS Sabertooth Z77 Memory: Corsair XMS3 8Gb 1600Mhz VGA: ASUS GeForce GTX 780 Ti Matrix PSU: Corsair AX860i
Storage: Samsung 850 Pro, OCZ Vertex 4 128Gb, WD Green 2Tb Case: Corsair 760T Monitor: Acer Predator XB1 + LG IPS234
https://linustechtips.com/topic/140318-h105-pump-noise/#findComment-2528616
i have also the pump hooked up to a pwm header but no matter what i do, i cant change speed at all, its not getting quieter or anything and its on 25%.
I'm using a z87 MSI board and their pretty crappy command center, works fine with everything else though.
https://linustechtips.com/topic/140318-h105-pump-noise/#findComment-2529492
