Question about static mats (for components)
Solved by tkitch,
So, here's the thing about static mats / straps:
Unless you're working in a high-tech lab, using exceptionally sensitive equipment? Mats do next to fucking nothing.
PC Equipment is not especially static vulnerable. Go watch the LTT / Electroboom video for evidence.
If you want to build a PC: Build it on a table. Plug in the PSU to the wall, and touch the metal case of the PSU occasionally. (The case is grounded.)
Don't walk around shuffling your feet on carpet trying to build up static, and you won't have any issues.
