Hello I need help what to buy first
I have r5 3600 and gt 710 and I was planning to buy rtx 3060ti with it or should i upgrade to r5 5600x and will still use gt 710 and wait for rtx 4000 series to come out ?
orr should i go r5 3600 and with rtx 3060ti
which one is the better choice need help
https://linustechtips.com/topic/1400666-need-help-what-is-better/
For what?
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
3600 + 3060ti is a workable system, 5600 + 710 is, ehem, underwhelming.
So it is your choice - do you want to have a better experience now or later. Performance advantage from upgrading GPU now vs CPU now for gaming is going to be significant.
Current system. CPU: AMD Ryzen 7 5800X; MoBo: Gigabyte X570S Aorus Master; RAM: 2x Crucial Ballistix MAX 2x8 GB (BLM2K8G40C18U4B); GPU: RX 6900 XT Gigabyte Aorus Master; case: Fractal Design Meshify-2; Storage: Samsung 980PRO 1TB NVMe SSD + 2x Samsung 980 1TB NVMe SSD; PSU: Seasonic Focus GX-850; Cooling: Arctic Liquid Freezer II 360.
well because umm i see some benchmark they use the same gpu but different cpu like 5600x vs 3600 there is a large different in fps well i guess 3060ti is a best choice and upgrade soon the cpu i think is the best choice do you think prices of gpu this year will go down ? after july or before july ?
The difference in FPS by changing your graphics card to a 3060ti will far surpass the increase in fps by upgrading your CPU.
19 minutes ago, Sheanfabs said:
I just need some help what is the best choice to go for now buy r5 5600x and keep the gt 710 and wait for rtx 4000 or keep the r5 3600 and buy rtx 3060ti
I understand that. I am asking you what the system is used for.
2 hours ago, Sheanfabs said:
just some video editing and gaming or maybe streaming
The GT 710 is basically useless for gaming, as I would think you'd know if you already have it.
The 3600+3060 ti is a far more capable all-around system.
