Spilled water into pc. Red cpu and dram light after taking apart and drying. Can't figure out what's damaged.
Solved by szdawid2,
When the water landed on the GPU, it may have shorted the PCI-E port, that may have a caused the DEATH of your CPU, you should try every component (except the CPU in your friends PC), and if they work, then the CPU died, but please be careful with the gpu, it can short your friends PC and it wouidn't be a good thing.
Featured Topics
Tyraenel 路
XxWOODSIExX 路
Posted in Troubleshooting2 -
Pove 路
Posted in New Builds and Planning7 -
4
tommmie20000 路
Posted in Audio5 -
INotPablo 路
Posted in Cases and Mods2 -
Pove 路
Posted in Power Supplies6 -
Knugen1015 路
Posted in Windows3
