>cheap
>100% legit
Pick one.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1398682-help-with-window-key/#findComment-15172151
13 minutes ago, pythonmegapixel said:
(I think the forum rules disallow advice on obtaining proprietary software other than through the legitimate channels provided by the developer)
Does it? I has legit site with legit keys OEM/Retail.
I've used the same key on like 5 different systems.
First watercooled System
Build Name: White Knight
OS: Windows 11 Pro 64-bit
Monitor: Alienware AW3423DWF 1800R Curved Ultrawide 3440x1440 QD-OLED 157hz 10 bit 0.1ms
Chassis: Lian Li 011 Dynamic EVO w/ 2x120mm Corsair QL RGB Fans on the bottom 1x120mm on back exhaust
Top Rad & Fans:  Corsair 54mm 360mm w/ 3x120mm Corsair ML Pro RGB Fans
Side Rad & Fans: Corsair 30mm 360mm w/ 3x120mm Corsair QL RGB Fans
Motherboard: Asrock X670E Steel Legend
CPU: AMD Ryzen 7 7800X3D w/ Corsair XC7 RGB Pro w/ Kyrosheet
Memory/RAM: Corsair Dominator RGB DDR5 2x16GB 32GB 6000Mhz
GPU: Asus GeForce RTX 4080 TUF w/ EK-Quantum Vector2 Nickel/Plexi & Backplate
Pump/Reservoir: Corsair XD5 RGB
Coolant: Corsair Clear
PSU: Lian Li Edge 1000W
Boot/OS SSD: Samsung 970 EVO Plus 500GB NVMe
WZ/2042 SSD: Samsung 850 EVO 250GB
Game SSD: Samsung 980 Pro 1TB
Performance/Editing HDD: Western Digital Black 1TB
Storage HDD: Western Digital Blue 1TB
Mouse: Razer Lancehead Tournament Edition/Razer Mamba
Mouse Mat: Corsair MM700 RGB
Keyboard: Razer Ornata Chroma
Microphone: Beacn Mic
Headset: Razer Blackshark v2 Pro
Eyewear/Glasses: Gunnar Optiks Razer FPS/Gamer Advantage Liquid
Camera: Razer Kiyo Pro/OBSBOT Meet SE
https://linustechtips.com/topic/1398682-help-with-window-key/#findComment-15172165
11 minutes ago, Serju Iurcu said:
what is it
Am I allowed to post links even know the keys are 100% genuine?
https://linustechtips.com/topic/1398682-help-with-window-key/#findComment-15172186
-> Moved to Windows
Direct links to ads are not allowed as per eBay rule. Mentioning sites one can try is fine. Buying from grey markets is more about ethics than anything else.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1398682-help-with-window-key/#findComment-15172214
