New AIO fan starting to rattle after a month
Tech Reprise
Hi.
Just bought a Deepcool Castle 240EX A-RGB a month back and one of the fans has started to rattle. Its kind of like a scratchy rattling sound which occurs at 100% duty cycle and goes away at 88% and below.
The fan is advertised as a Hydro Bearing.
Here are the specs:
Fan Dimensions 120×120×25 mm
Fan Speed 500~1800 RPM±10%
Fan Airflow 69.34 CFM
Fan Air Pressure 2.42 mmAq
Fan Noise ≤30 dB(A)
Fan Connector 4-pin PWM
Bearing Type Hydro Bearing
I faced the exact same issue in another Deepcool Cooler which had a similar bearing.
Is this because of the bearing which looks like a glorified Sleeve bearing and since Deepcool is hiding the bearing mttf I suspect it to be a Sleeve bearing and not a true hydro bearing.
Will there be any performance decrease in AIO if I run it at a lower RPM (88% duty 1753rpm 60ish cfm /fan) ?New Recording.m4a
The noise can be heard twice in this short recording. I can upload a better one tomorrow. And one thing I forgot to mention is that the noise goes away if I push the blade very slightly to lower rpm.
  • AMD Ryzen 7 5700X Stock
  • B550 Aorus Elite V2 Rev1.2
  • G.Skill TridentZ RGB 3600Mhz 32gb (8gb x4)
  • MSI Mech 2X RX6600
  • Deepcool AK620 WH
  • Deepcool CK500 WH
  • Kingston A2000 250gb + WD Blue 1tb HDD, Sn550 1tb + MX500 1000gb
  • Antec EAG Pro 750 80+G
  • Benq Mobiuz EX2510 144Hz
29 minutes ago, NorKris said:
Lucky for u P12 ARGBs are cheap and much better 🙂
Sickleflow 120 argb's are cheaper than the P12 and I think have better airflow. How about the Silverstone Ab120r?
  • Deepcool AK620 WH
  • Deepcool CK500 WH
They'll ship a new one if you let know.
Or
Get different fans up to you
Or
At this point I am thinking its just sleeve bearing noise so not worth it as per me. Will try with some other fans for now.
  • Deepcool AK620 WH
  • Deepcool CK500 WH
might have better airflow. but noise to performance? never.
