I am looking for the smallest mini-ITX case I can find to go with an AM1 APU build. I am going to be using the ASRock AM1H-ITX which supports a 19V DC in instead if using an internal power supply. So I don't want a case with a power supply and I don't care what size power supply it accepts. I don't have a budget for the case and it doesn't need to support expansion card but does need an 5.25" bay or a space for a slot loaded drive would work too.
https://linustechtips.com/topic/139533-small-case-for-small-build/
Merry Christmas: http://www.lian-li.com/en/dt_portfolio/pc-tu100/
EDIT: Sorry, didn't read the 5.25" part correctly, here's an alternative: http://www.lian-li.com/en/dt_portfolio/pc-q28/
My Stuff! :D
My Stuff
  • Main Build - Soon to change due to it being dead
  • 4790k @ 4.7Ghz
  • Corsair 750D
  • Swiftech H320
  • MSI Z97s SLI
  • 7950 Vapor-X
  • 16GB Corsair Vengance  Blue LP 1600Mhz
  • 120GB Samsung 840
  • 2TB Seagate Barracuda
  • Corsair HX750
  • ​Peripherals
  • Logitech G700s
  • Bitfenix, Corsair, and Darkside cable extensions
  • Das Professional with Cherry MX Brown's & Custom Keycaps
  • 3x ASUS VS238H-P w/ Triple monitor mount in PLP
  • AudioTechnica ATH-M50's
  • Blue Yeti Microphone
  • TurtleBeach PX3 Wireless
  • Logitech C920 Webcam
  • Precision Audio Bookshelf Speakers
  • AudioSource AMP-100
  • Logitech G27 Racing setup
  • Laptop - Acer 7750G-9855
  • i7 2630QM
  • AMD 6650M GPU
  • 120GB Samsung 840 EVO
  • 8GB RAM
  • Operating System: Windows 7 Home Premium
  • Blu-ray Drive
  • Netbook - HP Pavillion DM1
  • AMD E-450 APU
  • 4GB RAM
  • 500gb HDD
  • OS: Ubuntu 12.04
  • Cell Phone - OnePlus One
  • 5.5-inch 1080p Screen
  • Qualcomm Snapdragon 801 processor @2.5Ghz
  • 13 Megapixel rear camera
  • 5 megapixel wide angle front facing camera
  • 3100 mAh non-removal battery
  • AC wifi
  • Cell Phone #2 - Nexus 5
  • 5 Inch 1080p Screen
  • Snapdragon 800
  • 8 megapixel rear camera
  • 1.3 megapixel front camera
  • 2300 mAh non-removable battery
  • AC wifi
  • Upgrades for 2014
  • GTX 970
  • i7 4690k
  • 16gb RAM
  • 1x 1440 or 1600p Monitor
  • Das Mechanical Keyboard
I'd say; get the Corsair 350D Windowed. It supports Micro-ATX too, but you may need the extra space when installing a Mini-ITX.
that thing is huge exactly what the op doesn t want.
try aeither an antec isk300,(sorry it has a psu) or an isk110 or mini box m350. both of the last cases will need an external odd tho it will be smaller even with that than an isk300.
Anything I write is just a comment, take is as such, there is no guarantees associated with anything I say.
ATX Portable rig (smaller than prodigy(LOL)) :  Nmedia 2800 | Gigabyte Z77x-ud3h  | Corsair HX1000 | Scythe Big Shuriken | i5 3570K  |  XFX R9 290 DoubleD | Corsair Vengeance 32GB
Silverstone ft03 mini. GHighly recommended. Slot loading DVD drive for it. Really small
