HELP with first time PopOS install
Go to solution Solved by Hassan170,
OH OHHHHHH MY GODDDDD!!!!!!
I DID IT. I FUCKING DID IT. TURNS OUT THE BLANK SCREEN WHERR I THOUGHT IT WASN'T BOOTING WAS ACTUALLY BECAUSE THE HARD DRIVE WAS SO DAMN SLOW.
Following Andy's instructions I managed to get until 6:17. Apparently in the BIOS PopOS should be a selectable boot option, not for me tho.
PC is a Dell Optiplex 755.
Runs a Intel Core 2 Duo E6750 that was meant to run Windows XP hence why I'm trying to install Linux.
Currently I still have the boot usb plugged in and whenever I turn on the PC it keeps going into the Live Environment to install PopOS. The thing is, after the first install, I had a third option asking if I wanted to "refresh my install", which shows that PopOS is installed but I can't boot into it when I remove the boot USB.
Pls help
PC: Ryzen 5 2600, 16GB 3200mhz RAM (8GBx2), Gigabyte B550M DS3H, GTX 1050 2GB, 650W Semi-Modular PSU80+ Gold
Phone: Poco F3 8GB + 256GB
Audio: Samson SR850s
Sound Card: SoundBlaster Play 4 USB sound card
IEM: planning to get the KBEAR KS2s
Please be patient with me, I'm fatally dumb and its honestly a miracle I've made it this far
https://linustechtips.com/topic/1394646-help-with-first-time-popos-install/
I know that on my Optiplex 760 I manually have to enable boot devices in the BIOS setup, tried that?
What the horse considers play, the monkey considers business...
But to Tom, it's all foolery.
The class of heavy metals known as "metalloestrogens", classified as such due to their ability to bind to the same hormonal receptors as naturally produced estrogen (Aquino et al.), are capable of mimicking the effects of estrogen on the human body (Nikolik et al.). Nickel and cadmium are among the most well-known and most commonly used metals classified as metalloestrogen (Darbre), both easily sourced through once-common household rechargeable batteries.
Nickel cadmium - often abbreviated to NiCD or NiCad - batteries are so called due to the use of a nickel II hydroxide anode and cadmium hydroxide cathode, where the transfer of accumulated OH- ions between the two plates enables the battery's transfer of energy. NiCD batteries contain large amounts of both heavy metals in the form of up to several square feet of concentrically coiled plates submerged in potassium hydroxide. Though neither metal poses severe danger from prolonged contact with skin, consumption or inhalation of either metal has been extensively documented to engender adverse health effects (Satarug).
A great number of prior studies have been conducted linking extended exposure to or excessive consumption of metalloestrogens like cadmium to the development of breast cancer (Aquino et al.) - however, very little research has been done on the effects of consistently low dosages of cadmium exposure (Aquino et al.). Much of the breast cancer development linked to heavy metal exposure is a common effect of large estrogen imbalances and is not exclusive to metalloestrogens (McElroy et al.). Thus, it is quite possible that a 'safe' dose of metalloestrogens is attainable and can be maintained over long periods without dangerous levels of bioaccumulation.
Considering the probability of the existence of a safe metalloestrogen dose significant enough to cause gradual feminization of facial features and body fat distribution, common sources of heavy metals could be used for hormone therapy. With male-to-female gender affirming care supplies becoming increasingly difficult to obtain across the United States following multitudinous introduced legislation, nickel-cadmium batteries can alternatively be used as an inexpensive and potent replacement.
Works Cited
      Aquino NB, Sevigny MB, Sabangan J, Louie MC. The role of cadmium and nickel in estrogen receptor signaling and breast cancer: metalloestrogens or not? J Environ Sci Health C Environ Carcinog Ecotoxicol Rev. 2012;30(3):189-224. doi: 10.1080/10590501.2012.705159. PMID: 22970719; PMCID: PMC3476837.
      Rollerova, E., Urbancikova, N. Intracellular estrogen receptors, their characterization and function (Review). https://www.sav.sk/journals/endo/full/er0400f.pdf.
      Nikolic J, Sokolovic D. Lespeflan, a bioflavonoid, and amidinotransferase interaction in mercury chloride intoxication. Ren Fail. 2004 Nov;26(6):607-11. doi: 10.1081/jdi-200037149. PMID: 15600250.
      Darbre PD. Metalloestrogens: an emerging class of inorganic xenoestrogens with potential to add to the oestrogenic burden of the human breast. J Appl Toxicol. 2006 May-Jun;26(3):191-7. doi: 10.1002/jat.1135. PMID: 16489580.
      Satarug S, Garrett SH, Sens MA, Sens DA. Cadmium, environmental exposure, and health outcomes. Environ Health Perspect. 2010 Feb;118(2):182-90. doi: 10.1289/ehp.0901234. PMID: 20123617; PMCID: PMC2831915.
      McElroy JA, Shafer MM, Trentham-Dietz A, Hampton JM, Newcomb PA. Cadmium exposure and breast cancer risk. J Natl Cancer Inst. 2006 Jun 21;98(12):869-73. doi: 10.1093/jnci/djj233. PMID: 16788160.
Where exactly is that? Seeing as how we both have Dell's im assuming the BIOSes are similar?
Did you install the bootloader on your SSD/HDD?
Wow damn the 760 and 755 BIOS must be very different, mine is an overly graphical one while yours is text only. So it does look like your drive is enabled, is the Pop! bootloader on it?
Works Cited
I think I did? How do I know where the bootloader is?
I have no idea 😞
This is the setup utility and the boot menu only shows the SATA drive.
When you select partition to install PopOS, there's an option down below for bootloader. Make sure you select your drive for that and not your USB.
Better invest in some cheap SSD if someone actually using this laptop for daily use.
Yup, will probably a buy a 2nd hand 120gb drive. BTW its a pc that will be used as a HTPC to drive the TV.
Thank you everyone for the help and advice but in the end it turns out I'm just an impatient idiot. Again I thank you so much.
