Intel UHD 730 WQHD max refresh rate?
By
Yaerox
in Graphics Cards
in Graphics Cards
Solved by YoungBlade,
That limitation is just based on the type of port used, which is why there are two different numbers for HDMI and DisplayPort. The HDMI support is HDMI 2.0b and the DP support is for version 1.4, but note that this also depends on the port on the motherboard. It looks like that motherboard is using the same ports as the max Intel spec, so you're good there.
1
2
3
ShayOh ·
Posted in Troubleshooting2 -
Newbietobe5467 ·
Posted in Troubleshooting3
play_circle_filled
Latest From Linus Tech Tips:
I Will NOT Give You $250 for Your Broken Game - WAN Show April 26, 2024
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
