Recommendations for PCIe wireless networking cards?
Solved by Falcon1986,
5 hours ago, stoicswe said:So, do you have suggestions and/or recommendations for a PCIe wireless networking cards...
Almost anything based on Intel's AX200 or AX210 should be fine. Even if you don't have a WiFi 6/6e wireless router/AP, they seem to perform just well on WiFi 5 without that much of a cost increase.
5 hours ago, stoicswe said:...that would suite gaming?
That's up to you, but WiFi is generally not going to give you the best latency for games that depend on such (e.g. online FPS, etc.).
