That Gigabyte has an M.2 slot:
Quote
1 x M.2 connector (Socket 3, M key, type 2242/2260/2280 SATA and PCIe x4/x2 SSD support)
The Kingston SSD is an PCIe M.2 SSD (also known as 'NVME'), which works with this motherboard
You need a standoff and a screw to install the SSD, which either came in a loose bag with the motherboard, or are both installed on the motherboard already.
