TV Mount for 65'' LG CX
Wojo
Hey!
I need to find a mount for a 65'' CX.  Any help or suggestions would be appreciated.
It will be mounted on a wall that people will walk by so low profile or the ability to turn slightly so the edge of the TV hits the wall and hides the back would work.
I would also like it to extend out at least 19''.
I know with the CX having lower mounting holes might cause some issues with certain mounts so that is why I am asking.
The Echogear seems like an OK option https://www.amazon.com/ECHOGEAR-Articulating-Bracket-Patterns-Extension/dp/B07SH29BVX?tag=gfingenius-20&geniuslink=true&th=1
Thanks!
