Optical HDMI 2.1 = expensive
The cheapest one i found that also fully works cost me 170€ for 10m (approx. 30ft)
But beware: There are MANY cables being sold that do not fully work with HDMI 2.1. It's basically trial and error, so make sure you buy somewhere with a good return policy like amazon.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
https://linustechtips.com/topic/1392611-hdmi-21-optical-cable/#findComment-15132024
