This is going to be a realtime build log as I want tips and tricks.  That means I'll actually be going through the build as I post the pictures.  The bid for my Macbook pro ends tomorrow so I've made this a little early and will order the parts the next day.
Firstly, I would like to thank everyone who has helped me choose and organise this build esspecially @Str_Mape who has really helped me choose parts and has given me vital tips and tricks that will be essential for completing this build.
The parts I've chosen to order are a little odd I know, but I wanted reliability and component quality over all for this build.  I've also decided to add a keyboard and headset to this build, I hate my blackwidow keyboard (kinda) it has no backlight and I cant remove the keycaps.
Please note all edited parts will be in red text
So without further or do, heres my plan:
SSD: Samsung 840 EVO 120GB
HDD: Seagate Barracuda 2TB (from old rig)
Memory: Corsair Vengance DDR3 1600mhz (cl9)
Power Supply: Seasonic G series 550watt
CPU: Intel core i5 4670k
GPU: Asus DCU2 Top, AMD r9 270x (cuz, mantle)
Motherboard: Asus z87 Gryphon (comes with free armour kit)
Case: Corsair Obsidian Series 350D
Cooler: Cooler Master Hyper 212 EVO
Keyboard: Logitech G710+
Headset: Logitech G230
Mouse: Logitech G400s
Wifi Card: Tp-link wifi card
optical drive: Some asus thingy from old rig
Windows: Windows 8.1 64bit OEM
Advise would be much appreciated. Thanks everyone! SO EXITED!!!!!!
https://linustechtips.com/topic/139174-my-first-build-d/
OMG a build where I don't see an MSI motherboard and a Corsair psu. I am so happy just seeing this right now. I can't even compose myself to comment on the rest of the build.
I think ASUS ROG and corsair is the most used combo lol
i5 4670k| Asrock H81M-ITX| EVGA Nex 650g| WD Black 500Gb| H100 with SP120s| ASUS Matrix 7970 Platinum (just sold)| Patriot Venom 1600Mhz 8Gb| Bitfenix Prodigy. Build log in progress
Build Log here: http://linustechtips.com/main/topic/119926-yin-yang-prodigy-update-2-26-14/
https://linustechtips.com/topic/139174-my-first-build-d/#findComment-1855789
It doesn't mean it is the right thing to do though. I would much rather have Antec and Seasonic than Corsair and I don't care that Corsair is rebranded Seasonic cuz I bet they don't get Seasonic's best stuff so whatever.
Too many ****ing games!  Back log 4 life! :S
https://linustechtips.com/topic/139174-my-first-build-d/#findComment-1855796
MSI and Corsair too mainstream for you? :)
check my specs
MSI doesn't make the best motherboards and there are affordable options that are better than what they offer. I would not trust MSI motherboards in my pc builds. As for Corsair I made my point and it is correct. Antec and Seasonic are better.
https://linustechtips.com/topic/139174-my-first-build-d/#findComment-1855914
well I was not making a point I just like the branding on everything
https://linustechtips.com/topic/139174-my-first-build-d/#findComment-1855989
UPDATE:
I am now going to order the parts VERY SOON.  I've made a few changes based on your feedback (thanks btw)
HDD: My old Seagate Barracuda 2TB
PSU: Seasonic G Series 550watt
Case: Corsair 350D
Memory: 8GB Corsair Vengnace 1600mhz
GPU: Asus DCUII r9 270x
Cooler: Cooler Master Hyper 212 EVO (Found one at PCforce!! WOO)
OS: Windows 8.1 64bit OEM
https://linustechtips.com/topic/139174-my-first-build-d/#findComment-1856768
I have always had good performance and luck from MSI products. I suppose they are the same as any other brand, Sometimes you can get a lemon, And Corsair I really do not have much experiance with them, I do own a new CX600 V3 made by corsair with CWT insides. But I have not owned it long enough yet to determine how long they run. But it has done fine so far. The quality of it appeared nicer than the other PSU's in it's price range. Seasonic and Antec are very good products. But to say they are better than Corsair is just opinion and does not really help the guy. He should just go with any good brand that provides what he needs at the best price.
CPU: Intel i5 3470@3.8ghz, Motherboard: Biostar TZ77A, Ram: 8GB G.Skill Ripjaws 1600, GPU: EVGA SC GTX 970 ACX 2.0 , PSU: Corsair CX600, Case: Antec 300, OS: Windows 8.1 Pro 64
https://linustechtips.com/topic/139174-my-first-build-d/#findComment-1856919
OP it always feels good to put together a pc. I feel a sense of accomplishment and I know because I selected parts myself and with others help at times that I am going to be happy with the computer I get. I hope you will enjoy building and then using your pc in the future.
https://linustechtips.com/topic/139174-my-first-build-d/#findComment-1857007
The 760 is a bit underpowered for the i5, consider beefing up the gpu horsepower.
The 760 is a perfect match for the i5. There is nothing wrong with that choice.
Ryzen 1600@3.8ghz / 16gb 2400mhzASRock B350 ITX / Gigabyte RX 470 4gb / 256gb M.2 / SG13B-Q / Corsair 450w
https://linustechtips.com/topic/139174-my-first-build-d/#findComment-1858192
the i5 is a more powerful cpu than a lot of people think.
No, nothing wrong with being able to fit a more powerful gpu in there in the future, but it's not exactly the most economic choice. I would have gone with an fx-8320 or even 8150 if I was trying to save money.
Woo!
https://linustechtips.com/topic/139174-my-first-build-d/#findComment-1858288
I chose the r9 270x.  I think its better value becauses its $80 CHEAPER where I live.  I could then buy a better cooler, motherboard and CPU!
https://linustechtips.com/topic/139174-my-first-build-d/#findComment-1860008
Well.  I wanted to go Intel for compatibility and ease mainly, I dont know much about AMD and felt more confident going Intel.  At least it gives me upgrade room in the future :)
https://linustechtips.com/topic/139174-my-first-build-d/#findComment-1860019
Well that Noctua cooler is too small and won't be sufficient even without Ocing. Get something tower like, most of them fit on ATX/Matx boards.
I ordered a Cooler Master Hyper 212 EVO.  I think that should be sufficient.
https://linustechtips.com/topic/139174-my-first-build-d/#findComment-1860024
Thats because I dont have access to MSI motherboards in NewZealand (I think).  But I would go Asus and Seasonic anyways because Linus recommends them, not saying he doesnt recommend MSI and corsair but also because hes done build guides with Seasonic and Asus.
https://linustechtips.com/topic/139174-my-first-build-d/#findComment-1860031
