I would like to build a small formfactor PC for travelling with hardware I already have at home. Therefore I'm looking for a small case which can handle a mATX motherboard, two slot GPU (200mm) and an ATX PSU. Price should be less then 100€ (GER). Currently I'm looking at the Jonsbo V4 which is available for around 60-65€ but I would like to get some other recommendations.
I'm not too concerned about cooling since the Hardware I'm using isn't that power hungry.
 -+-+- This is a reminder to clean the dust filters of your PC! -+-+-
Main PC:
Ryzen 5 1600 3.8GHz - RX 570 4GB - 2x8GB DDR4 - ASUS Prime X370-Pro - Shadow Rock 2 - Define S - Seasonic Prime Gold 650W
500GB NVME SSD - 1TB SATA SSD - 1TB HDD - Windows 10 Pro
Dorm PC:
i5 4590 - GTX 960 4GB - 2x4GB DDR3 - ASUS H81M2 - Dark Rock 3 - Define R3 - 250GB SATA SSD - Seasonic S12 430W - Windows 10 Pro - Linux Mint
NAS:
Pentium G4400 - 4GB DDR4 - Fujitsu Esprimo P556 - 250GB SATA SSD - 2 x 4TB NAS HDD - 12V PSU - OpenMediaVault
Laptop:
Dell Latitude E6520 - i5 2430M - 2x4GB DDR3 - 250GB SATA SSD - Windows 10 Pro - Linux Mint
https://linustechtips.com/topic/1390078-small-matx-case-needed/
Thermaltake Core V21
Fractal Design Node 304
https://linustechtips.com/topic/1390078-small-matx-case-needed/#findComment-15114146
Thanks for your recommendations! I don't really like the look of the Core V21. The Node 304 seems like a good choice but sadly it's only ITX.
Main PC:
Dorm PC:
NAS:
Laptop:
https://linustechtips.com/topic/1390078-small-matx-case-needed/#findComment-15114176
  • silverstone fara series (i'm personally using silverstone tj08-e as my unraid with six 3.5 HDD)
  • coolermaster nr400 (not sure if your country can find those without ODD)
  • montech air 100 lite matx
  • phanteks evolv matx (nice but out of your budget)
Ryzen 5700x + EK Supremacy D-RGB | 2x8 GB DDR4 Klevv 3200 MT/s | MSI B550M Mortar | Palit 3070 GamingPro LHR + Bykski N-PT3070PRO-X | Corsair RM750 | Alphacool EPDM + QDC | Aquacomputer Quadro + HighFlow2 | EK D5 XTOP | Freezemod 360 30mm rad + Barrow Dabel-20b 360 20mm | Barrow & Freezemod fittings | Corsair 5000D Airflow
Audio: beyerdynamic DT 900 Pro X + iFi ZEN Air DAC + Razer Seiren Mini
https://linustechtips.com/topic/1390078-small-matx-case-needed/#findComment-15115463
@fonzz1e @tkitch Thanks for your recommendations!
I also did some more research by myself. The Inter Tech IM-1 Pocket (also sold as Tecware Fusion/SAMA IM01) seems to be exactly what I was looking for.
Main PC:
Dorm PC:
NAS:
Laptop:
https://linustechtips.com/topic/1390078-small-matx-case-needed/#findComment-15116220
that works too 🙂
if yer using non-sfx psu, it's gonna be tight
https://linustechtips.com/topic/1390078-small-matx-case-needed/#findComment-15117017
12 hours ago, fonzz1e said:
that works too 🙂
I'll try using my existing ATX PSU. I guess it'll be fine since my GPU is short enough to fit with an ATX PSU installed.
Main PC:
Dorm PC:
NAS:
Laptop:
https://linustechtips.com/topic/1390078-small-matx-case-needed/#findComment-15117890
  • 2 weeks later...
If you need pointers on the Intertech IM 1, shoot. I got it with an ATX PSU and I have tried inverted and regular setup.
PC: AMD Ryzen 7 7700 || Noctua NH-U12S SE2 || 32GB DDR5 6000 CL32  ||
|| Powercolor RX 9070 Reaper || Asus B650E-I
  || WD 850X 2TB ||  Corsair SF600 || Intertech IM 1 |||
Peripherals: Sennheiser PC  360 G4ME || AOC CQ27G2U || Viewsonic PX701HD || Keychron V1 || Logitech G303 Shroud Edition||| Laptop: XPS 13 2in1 7390 || Steam Deck 256 GB (64GB Version) ||| Cameras: Fujifilm XH-1 || Fujifilm X100T
Elite 110 build log (update:05/15/2018)
https://linustechtips.com/topic/1390078-small-matx-case-needed/#findComment-15134239
