pc case for evga sr2?
Go to solution Solved by herb,
so i did some searching and i found a company called Mountain Mods. they are a similar company to what Case Labs was but they seem to do a lot more customization and they have a wider range of products.
regardless, they have a selection of cases that have an optional hptx motherboard tray for the sr-2/sr-x. i decided to pick the "pinnacle 24" case with the hptx tray but they have 6 total options for hptx compatible cases.
here is a link to their page: https://www.mountainmods.com/index.php
here is a link to the sr2 tray and supported case list: https://www.mountainmods.com/product_info.php?products_id=567
NOTICE: for anyone in the future who wants to build a pc with the sr2, you do not have to buy the tray separately! some of the cases on the list have the hptx option built in! dont waste your money!
I don't think anyone makes HPTX cases anymore. Maybe try and get a second hand 900D or something?
Oh, maybe a Lian Li PC-A75X? I can see them in stock at a few UK sellers.
[ P R O J E C T _ M E L L I F E R A ]
[ 5900X @4.7GHz PBO2 | X570S Aorus Pro | 32GB GSkill Trident Z 3600MHz CL16 | EK-Quantum Reflection ]
[ ASUS RTX4080 TUF OC @3000MHz | O11D-XL | HardwareLabs GTS and GTX 360mm | XSPC D5 SATA ]
[ TechN / Phanteks G40 Blocks | Corsair AX750 | ROG Swift PG279Q | Q-Acoustics 2010i | Sabaj A4 ]
P R O J E C T | S A N D W A S P
6900K | RTX2080 | 32GB DDR4-3000 | Custom Loop
https://linustechtips.com/topic/1389207-pc-case-for-evga-sr2/#findComment-15107906
4 hours ago, herb said:
no it wont, its hptx which means you need a case with 9 pcie slots in length and a width even more than eatx.
so doe the case need hptx mounting holes? or just a case with 9+ pci slots and eatx?
Fractal Design Meshify 2 XL
https://www.newegg.com/p/pl?d=hptx+cases
https://www.ebay.ca/itm/Lian-Li-PC-A75-Black-Aluminum-ATX-Full-Tower-Computer-Case-fits-HPTX-Mobos/333700137375?hash=item4db214019f:g:y4EAAOSwWhlfRXgR
https://www.mountainmods.com/product_info.php?products_id=568
Edited by thrasher_565
https://linustechtips.com/topic/1389207-pc-case-for-evga-sr2/#findComment-15108433
10 hours ago, thrasher_565 said:
The sr series needs at least atx mounting holes and a wide chassis with 9 pcie slots. People have put it in multiple cases that do not at all support it but are big enough for it and it's fine.
https://linustechtips.com/topic/1389207-pc-case-for-evga-sr2/#findComment-15109084
if it can use some of the atx holes should be easy to drill new holes i would think. if that's the case pc part picker lets you search cases by pci slots then you need to find the width.
https://linustechtips.com/topic/1389207-pc-case-for-evga-sr2/#findComment-15109406
It would be far easier to just buy the readily available PC-A75X which will happily house a HPTX board and has all the correct mounting hardware.
https://linustechtips.com/topic/1389207-pc-case-for-evga-sr2/#findComment-15110741
https://linustechtips.com/topic/1389207-pc-case-for-evga-sr2/#findComment-15111415
