Kingston A2000 + Z97 Speed question
Solved by Electronics Wizardy,
1 minute ago, Nizar77 said:ok.... so can I get full speed if I use this Adapter ? and does windows10 boot from it? https://www.bol.com/nl/nl/p/akasa-m-2-ssd-naar-pcie-adapter-card-met-heatsink-cooler/9300000021037976/?Referrer=ADVNLGOO002013-G-123000350600-S-1157988279791-9300000021037976&gclid=CjwKCAiA7dKMBhBCEiwAO_crFKalHqAJRywFhLQ8vQjddwL1w7JT1umj3qt3dCEZv076srJnPeklJRoCowcQAvD_BwE
Nope, same speed limited as the chipset is limted to gen 2 speeds. You can get it faster if you use the cpu lanes, but then your gpu will run at much slower speeds.
But the this won't affect speeds in almost all uses, I woudl't bother.
Just keep it the way it is, it will be fine.
