Hello everybody,
First time poster, long time reader.
I recently upgraded to a 12900K and got the Gigabyte Z690 Gaming X DDR4 motherboard to go along with it. I kept my ram from my previous build, G.SKILL TridentZ for the Z370/X299 chipset (I just realized that it was for this chipset).
My issue is that I can only run my ram on the new build at 2133mhz and whenever I enable XMP at 3600mhz or 3200mhz, I get the black screen of death. I've reset the bios and everything is stable but the RAM is still clocked at 2133mhz.
So I'm wondering:
Am I out of luck with this ram set and should buy a new set? (Not ideal since I spent the bag on the new CPU)
How much performance am I leaving on the table with the RAM clocked as is?
Any help is appreciated.
Thank you.
- Jarron
UPDATE: Got the ram working at 3000mhz. My ram set is not listed on the memory support list for this motherboard but it's stable and running.
https://linustechtips.com/topic/1388834-12900k-xmp-issues/
What is the speed the kit is rated at?
Ryzen 7 5700X3D (CO -30) - AX370-Gaming 5 - 2x16GB @3600C18 - EVGA RTX 3070 8G XC3
[PBO2] CO -25/-25/-30/-30/-30/-30/-30/-30
[BIOS] Vsoc 1.1 / DRAM XMP
i5-6400 4.38GHz @1.36v (162.2 BCLK) - Z170M-Plus - 2x8GB @3244C16- Biostar RX 570 8G w/ MSI Armor cooler
[BIOS] BCLK: 162.2 (x27) / Vcore 1.35 / DRAM 3244 (XMP timings) / FCLK 1GHz (1622) / RebarUEFI patched
ROG G531GT : i7-9750H (uv) - GTX 1650 +700mem - 16+8GB @2666 - 1920x1080@145Hz (up to 172Hz) IPS panel
[Throttlestop] FIVR - Vcore -160 / Vcache -105 / iGPU+unslice -125 (IccMax 255)
i5-4690K + Z97-AR + Panram Blue DDR3 2800 2x4GB Lightsaber Blue
iMac 21.5" (late 2011) : i5-2400S - Samsung 4x4GB PC3-1333 - HD 6750M 512MB - cheap Winten SSD (MacOS High Sierra) - 1920x1080@60 LCD
Acer Z5610 "Theatre" Core 2 Quad Q9550 - 2x2GB PC3-1333 (Samsung) - 1920x1080@60Hz Touch LCD - great internal speakers
https://linustechtips.com/topic/1388834-12900k-xmp-issues/#findComment-15104971
Been hearing issues about Gigabyte Z690 and DDR4. Seems you aren't the only one.
Hope they fix it soon.
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
https://linustechtips.com/topic/1388834-12900k-xmp-issues/#findComment-15105810
Update: Got the ram working at 3000mhz. My ram set is not listed on the memory support list for this motherboard but it's stable and running.
https://linustechtips.com/topic/1388834-12900k-xmp-issues/#findComment-15106541
If you have not yet, there was a bios update two days ago, version F6a that is supposed to have fixed the XMP issues. If you try that it may allow you to get it running with your full memory speeds.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1388834-12900k-xmp-issues/#findComment-15116696
  • 11 months later...
Hi everyone.
ive been facing the same issues windows 11 on Intel i9 - 12900k with rog maximus z690 hero i have 128GB ram (4 sticks of 32GB) rated at 5200 ddr5 but im only able to use it at 4000Mhz as it bsod and crashes and does  ram training and never resolvesss when i trun on xmp. but when i use two sticks and xmp it works fine at 5200Mhz.
Havnt figured out a fix for this and not much is available online for these issues
is it the motherboard or the ram or is it the processor itself
https://linustechtips.com/topic/1388834-12900k-xmp-issues/#findComment-15667512
