I was given a basket with a bunch of old PC junk like cables and what not and it included an upgraded Acer Aspire xc100 desktop, the upgrade was a Corsair Vengeance 16gb ddr3 ram stick and an SK Hynix 256gb SSD. The issue with the computer is that it won't display on any monitor and I believe it must be a problem with the CPU, I came to this conclusion after plugging in my keyboard and mouse and the lights not turning on, I took that as a sign that the CPU wasn't working. Any tips on how I resolve this? My first idea was by removing the CPU but I couldn't seem to figure out how to remove the screw. Any and all help is appreciated thank you,
https://linustechtips.com/topic/1388314-cpu-help/
Try with the original memory. It might not support the 16GB Corsair Vengeance memory you're using.
It looks like the CPU cooler has 4 plastic screws on springs. If you gently press down and rotate half a turn they should come undone.
It's also very possible that the PC is just dead and why it was left in the junk pile.
https://linustechtips.com/topic/1388314-cpu-help/#findComment-15101456
