Gigabyte 2060 Fan Stops and Noise
NickVR
Hello,
Wondering if anyone has had this issue before.. I have found some complaining about coil whine but this is much worse.
Over the weekend my GPU started making an awful noise, sounded like rubbing almost. I read some people complaining about the fans being loose, so I tightened the 3 screws behind the fan blades, no change.
When on a lower fan curve on afterburner, under 30% or so the fan doesnt even have enough power to spin, it starts up and then makes a horrendous noise and stops again.
When at higher speeds there is a noise that almost sounds like it's hitting something.
When the fans are off I can notice a substance amount of movement in the fan vs. the 2nd gpu fan.
Video: https://www.youtube.com/watch?v=7jlRkLN0TeQ
Anyone have any suggestions?
The card is about 1.5 years old.
Seems like a fan bearing that's going bad.
Be sure to QUOTE or TAG me in your reply so I see it!
CPU Ryzen 7 5800X3D GPU EVGA 3080 Ti FTW3 Ultra MOBO Asus ROG Strix B550-F Gaming RAM Crucial Ballistix 3600 MHz CL16 32 GB PSU Corsair RM1000x COOLING Noctua NH-D15
