Budget (including currency): 500€
Country: France
Games, programs or workloads that it will be used for: Microsoft Office and other productivity apps (No 3d apps)
Other details: Must have wifi, no bigger than microATX
So I am in charge of building 2 PCs to replace some real old slow crap pcs. They are going to be used only on office works, no editing, no 3ds apps... Just browse and apps like Microsoft office
Basically trying to build something that with last for some years.
My initial idea was this build:
PCPartPicker Link
What you guys think?
https://linustechtips.com/topic/1387213-office-work-pc-build/
I believe you can get a better board with integrated wifi in it. Also a better drive with, as this one is only Sata. I believe there should be better cheaper SSD's for less. Maybe something like this:
So good CPU choice, this thing is fast enough. Switched the motherboard to one with Wifi for only 10 bucks more. 16GB or Ram because Office and an open browser will slow down performance. Just a bit more futureproofing. Went with a good NVMe SSD that has cache, so it is a bit snappier and has more longevity then the WD blue. Went for a cheaper case, as this one will also be enough. The PSU is also a bit cheaper and still enough. I believe this will suffice.
PCPartPicker Part List: https://fr.pcpartpicker.com/list/yJjNfP
CPU: Intel Core i3-10100 3.6 GHz Quad-Core Processor  (€137.05 @ Amazon France)
Motherboard: MSI B460M PRO-VDH WIFI Micro ATX LGA1200 Motherboard  (€99.99 @ Amazon France)
Memory: Patriot Viper 4 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  (€66.88 @ Alternate)
Storage: Western Digital SN750 500 GB M.2-2280 NVME Solid State Drive  (€62.99 @ Cdiscount)
Case: Thermaltake Versa H18 MicroATX Mini Tower Case  (€44.90 @ Amazon France)
Power Supply: EVGA BR 500 W 80+ Bronze Certified ATX Power Supply  (€44.56 @ Amazon France)
Total: €456.37
Generated by PCPartPicker 2021-11-09 10:33 CET+0100
https://linustechtips.com/topic/1387213-office-work-pc-build/#findComment-15092585
18 minutes ago, X_Splinter said:
PCPartPicker Link
1 minute ago, KKLawrence said:
DDR4-3200
The i3-10100 supports DDR4-2666. So anything higher is just a waste of money.
My build:
CPU
Intel Core i7 9700 8x 3.00GHz So.1151
CPU cooler
be quiet! Shadow Rock Slim
Motherboard
MSI B360-A PRO Intel B360 So.1151 Dual Channel DDR4 ATX
RAM
16GB (4x 4096MB) HyperX FURY black DDR4-2666
GPU
8GB Gigabyte GeForce RTX2070 WindForce 2X 3xDP/HDMI
SSD
500GB Samsung 970 Evo Plus M.2 2280
HDD
4000GB WD Red WD40EFRX Intellipower 64MB 3.5" (8.9cm) SATA 6Gb/s
Power Supply
bequiet! Straight Power 750W Platinum
Case
Fractal Design Define R6
3x bequiet! Silent Wings 3 PWM
https://linustechtips.com/topic/1387213-office-work-pc-build/#findComment-15092588
Id suggest going for a barebones like deskmini x300 then adding the cpu, rams, and storage. Heck you can even buy them prebuilt with all the parts included tho i wouldnt trust that since they prob cheap out on ram which is a horrible thing
Deskmini x300 formfactor is mini stx which is abit smaller than mini itx, for the parts buy a 3200g, 8x2 3200mhz sodimm rams, and a cheap m.2 like kingston a2000
https://linustechtips.com/topic/1387213-office-work-pc-build/#findComment-15092603
Oh, didnt know that
The cheapest 2666 kit is only 2 bucks cheaper, so I wouldnt call it a waste of money, just an oversight.
Crucial Ballistix 16 GB (2 x 8 GB) DDR4-2666 CL16 Memory (BL2K8G26C16U4W) - PCPartPicker
https://linustechtips.com/topic/1387213-office-work-pc-build/#findComment-15092606
For an OFFICE pc you sure got your priorities mixed up .... single channel memory will slow down the system,  you don't need a 80 euro case ...
Here's a build  WITHOUT video card.
Buy any used video card from eBay or whatever, it's stupid to spend 80 euro on a new video card
https://fr.pcpartpicker.com/list/qKyqxc
CPU: AMD Ryzen 5 1600 (12nm) 3.2 GHz 6-Core Processor  (€140.15 @ Amazon France)
Motherboard: Gigabyte B450M DS3H Micro ATX AM4 Motherboard  (€63.85 @ Amazon France)
Memory: Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3000 CL15 Memory  (€67.19 @ Amazon France)
Storage: Western Digital Blue SN550 500 GB M.2-2280 NVME Solid State Drive  (€54.49 @ Amazon France)
Case: Deepcool MATREXX 30 MicroATX Mini Tower Case  (€37.75 @ Amazon France)
Power Supply: Cooler Master MWE Bronze 450 W 80+ Bronze Certified ATX Power Supply  (€41.01 @ Amazon France)
Total: €404.44
Oh yeah, add a wireless card if you need to.
You could take the video card from the old systems, if they're pci-e cards.
Even if you buy a new video card at stupid high price of around 60-80 euro, you're still in the 500 euro budget.
Or find some used video cards locally for around 30-50 euro.
Something else you may want to consider ... those small form factor computers that Servethehome has reviewed lately
https://linustechtips.com/topic/1387213-office-work-pc-build/#findComment-15092615
Interesting these deskmini, maybe I will try the H470 version
https://linustechtips.com/topic/1387213-office-work-pc-build/#findComment-15094634
On intel version the advantage is cheaper cpus
On amd version the advantage is better graphics and if you go for the 5x00g cpus then youll also get better efficiency
https://linustechtips.com/topic/1387213-office-work-pc-build/#findComment-15094641
