2080 weird temp readings and fan performance
Dam_On
Hi
I have been experiencing some weird behavior with my graphics card.
When I start a game my GPU temp shoots from idle temp of 50*c to 78*c in less than a second before the menu screen has even loaded for the game and then sits at 77-79. As soon as you close the application the gpu temp drops to 50 within fractions of a second.
I have only noticed this as my gpu fans had started running at 100%.
If anyone has any ideas please let me know, or let me know im crazy
cheers for giving this a read
Intel Core i7-9700K
Nvidia RTX 2080
Corsair Vengeance LPX DDR4 3000 C15 4x8GB
Gigabyte GA-Z390 Gaming Sli-cf
5 minutes ago, Dam_On said:
... idle temp of 50*c ... as my gpu fans had started running at 100%
50c at idle? 100% fan speed?
Poor airflow in case? Dried thermalpaste?
Please tell what case you have and what fan configuration you're running - also if intake is filtered.
At idle, if you remove the side panel, does GPU temps drop?
PC Setup:
HYTE Y60 White/Black + Custom ColdZero ventilation sidepanel
Intel Core i7-10700K + Corsair Hydro Series H100x
G.SKILL TridentZ RGB 32GB (F4-3600C16Q-32GTZR)
ASUS ROG STRIX RTX 3080Ti OC LC
ASUS ROG STRIX Z490-G GAMING (Wi-Fi)
Samsung EVO Plus 1TB
Crucial MX500 2TB
Crucial MX300 1TB
Corsair HX1200i
Peripherals:
Samsung Odyssey Neo G9 G95NC 57"
Samsung Odyssey Neo G7 32"
ASUS ROG Harpe Ace Aim Lab Edition Wireless
ASUS ROG Claymore II Wireless
ASUS ROG Sheath BLK LTD'
Corsair SP2500
Beyerdynamic DT 770 PRO X (Limited Editon) & Beyerdynamic TYGR 300R + FiiO K7 DAC/AMP
RØDE VideoMic II + Elgato WAVE Mic Arm
Racing SIM Setup:
Sim-Lab GT1 EVO Sim Racing Cockpit + Sim-Lab GT1 EVO Single Screen holder
Svive Racing D1 Seat
Samsung Odyssey G9 49"
Simagic Alpha Mini
Simagic GT4 (Dual Clutch)
CSL Elite Pedals V2
Logitech K400 Plus
Hey cheers for the response mate
Sorry the fans will only run at 100% when the temp is reading 78c.
My case is a, cooler master masterbox lite 5 mid tower case, with 2 inlet fans at the front and 1 exhaust at the rear.
Is it normal for such fast temperature changes?
Fans going 100% from 78c and up sounds like a normal fan curve to me but 78c sounds too high IMO.
Also I read alot about the MasterBox Lite 5 having really bad airflow. You're probably suffocating your graphics card. Did you try taking off the case side panel and see if temps will drop? If my theory is correct, even your idle temps should begin to drop (from the 50c) when taking off the side panel.
And yes - temps rising fast is "normal" if the heat can't be dissipated.
PC Setup:
Crucial MX500 2TB
Crucial MX300 1TB
Corsair HX1200i
Peripherals:
Corsair SP2500
Racing SIM Setup:
Simagic Alpha Mini
CSL Elite Pedals V2
Logitech K400 Plus
Take a read here: Masterbox 5 Lite - SHIIIIT Airflow : coolermaster (reddit.com)
The airflow is appearently really, really bad. Taking off the front panel should help a lot!
Please, try take of the side and/or front panel and do a normal gaming session while monitoring your temps. You probably will see an improve, both in temps and GPU fan speeds.
PC Setup:
Crucial MX500 2TB
Crucial MX300 1TB
Corsair HX1200i
Peripherals:
Corsair SP2500
Racing SIM Setup:
Simagic Alpha Mini
CSL Elite Pedals V2
Logitech K400 Plus
Eh, these temp jumps are completely normal...
For example my gpu "jumps" from 30c idle to ~55c "as soon as I start a game"...  the only diff is that yours by default runs hotter -- which is still quite normal.
What happens is you "suddenly" pump more voltage into a small electrical part, which results in heat.
As long the gpu doesn't go above 80, 85c this is completely normal (and im frankly surprised someone would be surprised by that, gpus come with a fan(s) for a reason)
Which would indeed explain the overall high'ish temps ...
I also think 2000 series overall didn't have the greatest cooling?
-Scott Manley, 2021
Softwares used:
Corsair Link (Anime Edition)
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
Thank you guys very much, I'll let you guys know how things go with pulling the covers off
thank you for your help guys all looking great now
ok neverminded it was short lived. system was running great 29-31 idle and in game sitting at 55, restarted pc and now idle is still 30 and in game is back to 74-76, covers still off
But maybe your GPU is clocking higher than before now, which would also indicate that the cooling is much better.
PC Setup:
Crucial MX500 2TB
Crucial MX300 1TB
Corsair HX1200i
Peripherals:
Corsair SP2500
Racing SIM Setup:
Simagic Alpha Mini
CSL Elite Pedals V2
Logitech K400 Plus
Interesting I'm not seeing anything different in afterburner
