Higher FPS or Lesser Ghosting
A monitor with Higher FPS but with ghosting or Lower FPS but no ghosting. Backlight strobing seems to be the current method of removing ghosting with BenQ's DyAc performing the best. The comparison is a 240hz monitor with no backlight strobing feature meaning it'll have ghosting and a 144hz BenQ monitor with DyAc meaning it'll have no ghosting. So which is better 240hz with ghosting or 144hz with no ghosting for gaming experience ?
I am currently in a dilemma of purchasing a gaming monitor for myself and i have found a 240hz monitor similarly priced as a 144hz BenQ monitor with DyAc. However I don't which direction i should proceed, to having no ghosting but lesser fps or ghosting with higher fps. I mainly play FPS games like Apex Legends, Valorant and CSGO.
https://linustechtips.com/topic/1386834-higher-fps-or-lesser-ghosting/
Sounds like one of those personal preference things. Personally the ghosting would be bothersome.
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
LTT did a great video proving that 60Hz to 144Hz is indeed a competitive advantage, but with very big diminishing returns over 144Hz. However, they did ONLY test refresh rates, not clarity. My own educated guess would be that the 240Hz refresh rate still offers a slight advantage over a 144Hz monitor using DyAc because the input lag advantage is still at the higher refresh rate.
It would be helpful to know what exact monitors you're talking about to make a more informed recommendation.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
Also depends what fps you're getting, really I'd pick 240Hz myself but yeah it would be best to try out yourself to see. But also to pick what you can drive too.
| CPU: Ryzen 7 7800X3D | MOBO: AM5 B650 Aorus Elite AX | RAM: G.Skill Trident Z5 Neo RGB DDR5 32GB 6000MHz C30 | GPU: Sapphire PULSE Radeon RX 7900 XTX | SSD: Samsung 9100 PRO 1TB with heatsink | Cooler: Arctic Liquid Freezer II 360 | PSU: Seasonic Focus GX-850 | Case: Lian Li Lanccool III | Mousepad: Zowie GTF-X  / Vaxee PC / PA / Artisan Raiden Mid XXL| Mouse: Vaxee XE wired / Hitscan Hyperlight | Keyboard: Wooting 80HE zinc alloy raw - geon raw HE switches | Headset: Beyerdynamic MMX 300 (2nd Gen) | Monitor: LG 32GS95UV-B OLED 4K 240Hz / 1080p 480Hz dual-mode | OS: Windows 11 |
