Hey guys I need help.So I am new to the computer world and I have a question Is it normal that the cpu fan is continuously running even though I already shutdown my monitor/computer and Is it ok if I unplug my pc even though the fan is still running
This is the steps i do on shutting down my pc and Im worried cuz I think im doing wrong
1.shutdown
2.turnoff monitor
3.unplug
Edited by Numbawan
Typo
https://linustechtips.com/topic/1386060-cpu-fan/
What you're doing is what you have to do, but that's not normal for the CPU fan to do that. Something is either wrong with the OS or wrong with the BIOS. Try disabling fast startup both in Windows and in BIOS and see if that fixes it, and if that doesn't, maybe try a BIOS update.
https://linustechtips.com/topic/1386060-cpu-fan/#findComment-15084029
-> Moved to Cooling
This is not normal. Not, if it continues for more than 30s. High speed fans take some time to spin down. But if it just keeps going, you either don't actually shutdown. Or you have setting that keeps it powered when OS is shut down.
So please give some more details. Is this custom built? Pre-built? Laptop? What OS? Describe the issue bit more.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1386060-cpu-fan/#findComment-15085278
1.shutdown
2.turnoff monitor
3.unplug
are you using a powered dvi to hdmi adapter?
https://linustechtips.com/topic/1386060-cpu-fan/#findComment-15085301
1 hour ago, LogicalDrm said:
-> Moved to Cooling
heres a photo
https://linustechtips.com/topic/1386060-cpu-fan/#findComment-15085327
1 minute ago, Numbawan said:
heres a photo
That doesn't tell anything. Download Speccy and post screenshot of that. Though I can see from the upper picture that you have pre-built. Can you describe the issue more? Like when you select "shutdown" from OS, how long will fan keep spinning? If it's minutes, first thing is to make sure you are actually shutting it down. In some versions of Windows, it just goes to sleep and fans keep spinning. Also make sure it really is CPU fan and not HDD.
https://linustechtips.com/topic/1386060-cpu-fan/#findComment-15085334
