RTX2080Ti, 110% Power but only 75% usage ???
Solved by OneOfYas,
13 hours ago, Seabottom said:It's not an 8700k, it's a non-k, I'm running stock at 4.3 GHz. I didn't think my CPU was holding me back, it's only at 50% utilization in the screenshot anyway.
My question was why is my GPU not being 100% used if the frames are less than my monitors refresh rate? I could understand if I was at 80% usage and 100FPS, but when there's clearly more frames to be pushed and all the hardware is only at half load, surely more FPS could be produced?
Core usage is not the issue when a single core can only deliver so many FPS per core, if a game is stuck using 4 threads for example, you will never see it hit max usage.
