So I have a FoxPro game call for hunting and it stop working. After doing some inspection I noticed that the board does receive power but it doesn't do any else. Hooking a 9v battery to the connector instead of the battery pack I get a flash of the green and the speaker makes noises but nothing until I jiggle the connector and then I get noise again. I tested the board and it's getting power but I'm getting no output. I was wondering what I might be causeing this issue. Thanks in advance.
P.S
I attached photos of the board so you have a visual with I'm working with
https://linustechtips.com/topic/1385438-some-help-please/
Why are the pink and the brown wires, on the right side, disconnected? Was the solder joint broken or?
Thing is you can guess but i am not sure how to find the chip responsible for video output without schematics.
Did you try to google the board to check out what is available online?
https://linustechtips.com/topic/1385438-some-help-please/#findComment-15080203
9 hours ago, TechyHotdogWater said:
The pink and brown where for the antenna connection and I didn't find anything looking up the board, but I see multiple markings on the board with revisions and I'll see if I can find anything. Thanks for the response.
Please use reply button or tag people when you are responding with @Kadzo so i can see that you have responded.
If you are getting power but no output signal usually that means there is a problem with the display chip itself, of the connection from the board to the display.
Are there any visual signs of dead parts or corrosion on some parts?
Edit: did you check the screen itself? Eliminate the connection from the board to the screen, do a continuity test on the wires check all the solder points, then the screen, after that there is not much you can do besides checking the chips.
https://linustechtips.com/topic/1385438-some-help-please/#findComment-15081604
1 hour ago, ColinLTT said:
Im willing to bet these two wires got pulled from these two VIAs with solder in them
image.png.1c2eab527d2d8d9bc8f5bae6e821b16f.pngPersonally I'd say this makes more sense. Although I have no idea what these wires or this board are for and how they work. (could be the other way round of course)
https://linustechtips.com/topic/1385438-some-help-please/#findComment-15082386
could be either, agreed. Really just looking for what's off and guessing.
https://linustechtips.com/topic/1385438-some-help-please/#findComment-15082596
^this it clearly shows that something was soldered on those 2 solder pads and those wires are clearly part of that bundle go for it what could happen other than experiencing the joy of magic smoke!
My daily driver: The Wrath of Red: OS Windows 10 home edition / CPU Ryzen TR4 1950x 3.85GHz / Cooler Master MasterAir MA621P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / ASRock x399 Taichi / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / Samsung 512GB 970 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor x3
My technology Rig: The wizard: OS Windows 10 home edition / CPU Ryzen R7 1800x 3.95MHz / Corsair H110i / PSU Thermaltake Toughpower 750watt / ASUS CH 6 / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / 512GB 960 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor HP Monitor
My I don't use RigOS Windows 10 home edition / CPU Ryzen 1600x 3.85GHz / Cooler Master MasterAir MA620P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / MSI x370 Gaming Pro Carbon / Gskill Flare X 32GB DDR4 3200Mhz / Samsung PM961 256GB M.2 PCIe Internal SSDEVGA GeForce GTX 1050 Ti SSC GAMING / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor
My NAS: The storage miser: OS unRAID v. 6.9.0-beta25 / CPU Intel i7 6700 / Cooler Master MasterWatt Lite 500 Watt 80 Plus / ASUS Maximus viii Hero / 32GB Gskill RipJaw DDR4 3200Mhz / HP Mellanox ConnectX-2 10 GbE PCI-e G2 Dual SFP+ Ported Ethernet HCA NIC / 9 Drives total 29TB - 1 4TB seagate parity - 7 4TB WD Red data - 1 1TB laptop drive data - and 2 240GB Sandisk SSD's cache / Headless
Why did I buy this server: OS unRAID v. 6.9.0-beta25 / Dell R710 enterprise server with dual xeon E5530 / 48GB ecc ddr3 / Dell H310 6Gbps SAS HBA w/ LSI 9211-8i P20 IT / 4 450GB sas drives / headless
Just another server: OS Proxmox VE / Dell poweredge R410
https://linustechtips.com/topic/1385438-some-help-please/#findComment-15086137
