pump speed curve
Solved by For Science!,
2 minutes ago, Yousif-Nael said:So I got the Masterliquid ML240L v2 AIO in a front mount with a push fan setup and wanted to know what pump speed curve is the best to do? it's now on the default curve that the bios set it automatically
AIO pumps should be at max speed at all times, they are not powerful and can die earlier if they are spun any slower.
