Sometimes there is one USB port on a mobo that you can restore previous versions of the firmware with, but it doesn't look like yours has that feature.  Is it turning on at all?  Fans spin?  When I mess with my mobo too much it'll do a "boot for three tries" and then back to factory settings with my bios.
It must be true, I read it on the internet...
https://linustechtips.com/topic/1384298-no-post-bricked-mobo/#findComment-15070323
5 hours ago, Loka said:
Hello,
 it would seem I have blocked my motherboard. I needed to spoof to avoid an hwid ban and after doing this I do not post. I have tried resetting CMOS to avail 😞
anything else I can try?
I have Msi a320m a pro max
r3 3100
rx580 8gb
It’s really not clear what you mean. Do you mean you’ve BRICKED your mobo after updating your bios?
if so you can use a ch341a and a SOT-8 clIp on adapter to reflash a bios image. You’d be writing directly to the bios chip so would need a laptop and USB extension cable.91118D47-41E4-4EB3-9D42-1F57567DFDE8.thumb.jpeg.08ebaf5c7331198d1a749f72944b5155.jpeg
Pentium D 820 3.8ghz>e6600 3.6ghz>2500k 4.8ghz>3770k 4.6ghz>4790k(4.6ghz unstable crap)>8700k>qqlt 4.7ghz>3500x>5800x>9800x3d
https://linustechtips.com/topic/1384298-no-post-bricked-mobo/#findComment-15070768
Thanks for your help! I’m just really stupid and have 0 brain cells... the hdmi came lose😭 I’m so sorry, but tysm for the help you gave me it means alot
https://linustechtips.com/topic/1384298-no-post-bricked-mobo/#findComment-15072896
