PS4 Issues
Cuwee
I got a ‚new’ PS4 and everything seemed to be fine. However once i started using it I’m having issues with the controllers and it.
If I get it to turn on wirelessly, the controller will disconnect after about 10 minutes.
Then at other times the controllers won’t turn on the PS4 at all, wirelessly or wired.
If i fully reset the console, unplug it from power and replug it, it’ll work again for a bit.
Any ideas what’s causing this?
Since its new, i would bring it in for warranty.
Im sorry i dont have anything more useful to say.
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
Not willing to capitulate to the ignorance of the masses!
I've had issues with consoles waking from sleep due to HDMI CEC being on. Try turning that and all of the power saver settings off. If those don't work, return it/warranty it.
