6 minutes ago, Razorwire said:
https://pcpartpicker.com/list/Z2tg8J
This is my current build.
What graphics card and cpu should i upgrade to?
Maybe also the psu
what is your budget?
what is the use of your pc?
do you need pheripherals?
you need to tell way more info than this to give you any tips
Pls Mark a solution as a solution, would be really helpful.
BTW pls correct me, iam really stoobid at times.
https://linustechtips.com/topic/1382649-upgrade-path-for-my-pc/#findComment-15058198
Maybe also the psu
CPU support list for your mobo:
https://www.msi.com/Motherboard/support/B450-GAMING-PRO-CARBON-MAX-WIFI#support-cpu
(you will probably need to update your BIOS to use the latest Zen3 CPUs).
Now just because a CPU is on the support list it does not mean it is a good fit for the mobo, let's check how good are the VRMs on that mobo:
https://linustechtips.com/topic/1137619-motherboard-vrm-tier-list-v2-currently-amd-only/
Nothing spectacular, but not too bad either.
Now make a choice:
a) Stay with iGPU, Ryzen 7 5700G would be a nice pick.
b) Get a dedicated GPU. In that case for your CPU I'd recommend to go with Ryzen 5 5600X or Ryzen 7 5800X (depending on your budget and needs). If you go this route expect to pay a lot for a solid GPU and on top of that you will  have to replace your 400W PSU (another 120$ or so).
Without knowing your budget and what the PC will be used for I can't narrow it down further for you.
https://linustechtips.com/topic/1382649-upgrade-path-for-my-pc/#findComment-15058245
9 minutes ago, Razorwire said:
I use my Pc for gaming and i have a budget of around 400 cad
only for gaming or also streaming
https://linustechtips.com/topic/1382649-upgrade-path-for-my-pc/#findComment-15058414
do you need pheripherals like keyboard mouse monitor etc
https://linustechtips.com/topic/1382649-upgrade-path-for-my-pc/#findComment-15058434
Maybe also the psu
i think so this is the only thing you can get
the performance can be very very low in some cases
the other best option is to get xbox serise s
good console for gaming at 400cad
well if you really need a pc then this is a thing another guy named @SupaKomputa did for you: https://ca.pcpartpicker.com/list/WnK468
https://linustechtips.com/topic/1382649-upgrade-path-for-my-pc/#findComment-15058487
1 hour ago, Razorwire said:
I only game with a bit of light video editing and coding,
I don't need any peripharals.
oh really
iam a big fat fool!!
iam sorry iam not telling you iam telling my self
Edited by my name is guru iam tech
iam sorry i did not intended to tell you
https://linustechtips.com/topic/1382649-upgrade-path-for-my-pc/#findComment-15058490
and is it ok if the budget went upto 500+ cad
https://linustechtips.com/topic/1382649-upgrade-path-for-my-pc/#findComment-15058495
precisely 563 cad
https://linustechtips.com/topic/1382649-upgrade-path-for-my-pc/#findComment-15058496
PCPartPicker Part List
CPU: AMD Athlon 3000G (14nm) 3.5 GHz Dual-Core Processor  ($84.98 @ Newegg Canada)
Motherboard: ASRock B450M Pro4-F Micro ATX AM4 Motherboard  ($59.75 @ Vuugo)
Memory: Silicon Power 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($74.98 @ Amazon Canada)
Storage: Mushkin Enhanced Helix-LT 500 GB M.2-2280 NVME Solid State Drive  ($61.99 @ Amazon Canada)
Case: Cooler Master MasterBox Q300L MicroATX Mini Tower Case  ($49.75 @ Vuugo)
Power Supply: EVGA BR 450 W 80+ Bronze Certified ATX Power Supply  ($39.99 @ Amazon Canada)
Total: $371.44
Generated by PCPartPicker 2021-10-21 03:09 EDT-0400
https://linustechtips.com/topic/1382649-upgrade-path-for-my-pc/#findComment-15058544
Total: $371.44
wow
https://linustechtips.com/topic/1382649-upgrade-path-for-my-pc/#findComment-15058546
