Hi
I am an engineering student and so need to use various CAD programs, one of which is Siemens NX11. Whenever a sub-window (opened by NX11) and drag it around the screen to various points, a fairly obstructive visual glitch occurs (not quite sure how to describe it but I have a video of it anyway).
I am running it on a Dell XPS15 7590 (i7 9750H, GTX1650 and 8GB RAM) and have the most up-to-date graphics card drivers.
Thanks
https://linustechtips.com/topic/1381252-window-trailing-effect-glitch-help-pls/
@lou_new1Is it only in SIemens NX11? If yes, then you could try disabling Windows effects in
image.png.3914b3f96eeeb4e69cd79cca47dacbf8.pngimage.png.e2f88c5a388a0cb26f831567ebd58518.png
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
I tried this and it didn't work - not quite sure what this suggests to be honest. Any other suggestions?
Thanks for the reply!
Does this happen in other applications as well as NX11? Because this seems more like a problem with the software rather than anything else. Maybe go to the render settings for the viewport to adjust some settings. Or bring it up with Siemens directly. I've found a doc that claims a similar kind of bug apparently was fixed in a previous version, maybe it's a bug they have to fix on their end.
And now a word from our sponsor: 💩
ℑ𝔣 𝔶𝔬𝔲 𝔬𝔫𝔩𝔶 𝔫𝔬𝔱𝔦𝔠𝔢 𝔭𝔢𝔯𝔣𝔬𝔯𝔪𝔞𝔫𝔠𝔢 𝔭𝔯𝔬𝔟𝔩𝔢𝔪𝔰 𝔴𝔥𝔢𝔫 𝔶𝔬𝔲 𝔥𝔞𝔳𝔢 𝔞 𝔰𝔱𝔞𝔱 𝔠𝔬𝔲𝔫𝔱𝔢𝔯 𝔬𝔳𝔢𝔯𝔩𝔞𝔶 𝔞𝔠𝔱𝔦𝔳𝔢, 𝔶𝔬𝔲 𝔞𝔯𝔢 𝔪𝔢𝔯𝔢𝔩𝔶 𝔩𝔬𝔬𝔨𝔦𝔫𝔤 𝔣𝔬𝔯 𝔭𝔯𝔬𝔟𝔩𝔢𝔪𝔰 𝔱𝔬 𝔟𝔢 𝔲𝔭𝔰𝔢𝔱 𝔬𝔳𝔢𝔯. 𝔗𝔲𝔯𝔫 𝔬𝔣𝔣 𝔱𝔥𝔢 𝔠𝔬𝔲𝔫𝔱𝔢𝔯 𝔟𝔢𝔣𝔬𝔯𝔢 𝔞𝔰𝔨𝔦𝔫𝔤 𝔣𝔬𝔯 𝔥𝔢𝔩𝔭 𝔞𝔫𝔡 𝔰𝔢𝔢 𝔦𝔣 𝔶𝔬𝔲 𝔰𝔱𝔦𝔩𝔩 𝔫𝔬𝔱𝔦𝔠𝔢.
ᑐᑌᑐᑢ
  • 3 weeks later...
This is only an issue with NX - still haven't fixed it
